How to restart , quit frozen apps and reset iphone
I need to know what is happening with my iPhone. I was listening to music, when in my iPhone's iPod application, the phone was completely locked up at the end of the track, with an almost faded display and worse it became completely unresponsive.
Please help.
Best Answer by lee hung
Answered By 75 points N/A #81760
Consider forcing the application program to shut down. To get an application program to shut down, do these simple steps:
For iPhone or iPod touch operating iOS 3.0 or even later.
Step 1. Push and hold the Sleep/Wake key right up until the red-colored slider shows up. As soon as the red-colored slider is seen, let go of the Sleep/Wake button.
Step 2. Rather than dragging the red-colored slider, push and hold the Home button for about 6 seconds.
Step 3. In case the device really doesn't go back to the Home screen, check out the following methods to restart the device.
iPhone or iPod touch operating iOS 2.2.1 or earlier.
Step 1. Push and hold the Home button for 6 seconds.
Step 2. In case the device really doesn't go back to the Home screen, check out the following methods to restart the device.
In case you find that the iPhone or iPod touch continues to be unresponsive, consider restarting the device:
Restarting iPhone or iPod touch.
Step 1. In order to switch the device off, press and hold the Sleep/Wake button right until the red-colored slider shows up.
Step 2. Slide your finger across the slider in order to switch off an iPhone.
Step 3. To be able to switch iPhone or iPod touch on, press and hold the Sleep/Wake button until eventually the actual Apple logo shows up.
In the event, that the iPhone or iPod touch continues to be unresponsive, even after attempting the earlier mentioned procedures or perhaps in case it's in an unusual state, such as displaying a prolonged Apple company logo on the screen, try resetting the device:
Resetting the iPhone or iPod touch.
Step 1. Push and hold the Sleep/Wake button as well as the Home key simultaneously for no less than 10 seconds.
Step 2. Keep pressing and holding them both until eventually you notice the display screen go black and then the white Apple company logo shows up.
Step 3. As soon as this takes place, you may release holding – during this time, the iPhone is restarting.
In case you are worried, an iPhone reset is not going to get rid of any data or even settings.
Resetting the iPhone is sometimes also referred to deleting all content from the iPhone and restoring from a back-up.
For iPhone 4, iPhone 3 G and iPhone 3 GS, the reset process is similar.
Answered By 0 points N/A #81761
Your iPhone is completely locked up. So, you need to restart, quit frozen apps and reset your iPhone. You don't need to be getting worried because your problems are not so big. I have understood that you need clear solution. So, you can visit The Link to get salvations of your problems.
Also here: Here Is the step by step solutions of troubles. There are all the solutions of your problems such as restart the phone, quit frozen apps, reset iPhone and many more. I think following those instructions of troubleshooting is the best option to you. Good luck and enjoy with your iPhone.
