Sheena Wong
Posted on - 01/16/2012
My brother performing some kind of restoration in his laptop and now the entire program in the system, media player and all major software are all deleted. And my concern is, if you purchased the software and set up shop would view his start as normal working laptop with all the basic program.
How to restore deleted programs from laptop?
Recovering deleted programs on the computer will be a little bit tricky, but recovering deleted files will be easy. To try recovering the programs that you deleted, I will suggest that you do the following:
Click Start on your computer and then type system restore in the search box.
Press Enter on your keyboard to open the system restore window and then click Next.
Specify the restore point which should be a time before you deleted the programs and then start the system restore process.
Wait for it to finish.
After the process has finished and the computer has restarted, you will need to check if your programs have been recovered.
-Chalk Talk
