How to restore images transferred to folder using turbo network storage?
The images that I transferred to a new folder in my turbo network-attached storage did not update and were removed when I quit the application. The times when I attempted to re-launch the folder, the system prompted me to start over, but the images were still not saved in the folder. Is there a function in this application to restore the images that were lost during the transfer since I believe the data is backed up in a main folder?
Answered By 20 points N/A #109391
Those data is not restored in main folder but also it was not totally lost. So you can recover these data. There is no option or function in this application to restore the images that were lost during the transfer. To restore this you need to use some utility software to perform the task. You can use any recovery software for this. I will recommend Recover My File software utility to do this job. You can find it in many website. Then install it and use complete search for image search and recovery option. It will look like this one
