How to restore quicken 2000?
Hello guys,
How to restore quicken 2000? I reformatted my computer about 3 days ago and installed a windows 7 64 bit operating system. But suddenly when I tried to restore my applications it is not working at all. Can you help me restore the files?
I hope you can help me.
Best Answer by Rashel Mathew
Answered By 0 points N/A #173504
If you backup your programs on your drive D or in any external storage, then put it back after you format your computer. Chances are, your programs won't run any more because of missing DLL, or because of missing parts of the program.
The only way to restore your program is to install it again, then you will be able to overwrite the program by copying the backup and pasting it to C programs. If it still does not work, you have no choice but to delete it and install it again, and your backup program won't be usable anymore.
Nelson
Answered By 0 points N/A #173505
I have ever done restore on Quicken 2000, and it is fairly easy to do:
  1. Go to File, then select Backup and Restore, and then open the page Restore from Backup File.
  2. Find the backup file that you want to backup. Quicken files with extension QDF-backup.
  3. Double click on the backup file. Then it will appear pop-up windows. You need to specify the location to save the Quicken 2000 data file. Make sure it is located in the harddisk.
Answered By 0 points N/A #173506
Try to "restore" a file from a CD-ROM.
Using Windows XP, one must sometimes copy the source file from the CD-ROM to a convenient location on the local hard-drive. Give it a whirl. Make a folder on your Desktop. Give it a clever name. Copy the file(s) you need in order to perform the restoration of Quicken 2000 from the CD-ROM to the newly created folder.
Then, go into your Quicken 2000 and try restoring by pointing the software to the folder on the Desktop, rather than the CD-ROM.
Wish you luck.
Answered By 590495 points N/A #315073
You should check the system requirements of the program. If you change or upgrade your operating system to 64-bit Microsoft Windows 7 and the program no longer works, you need to check if the application supports 64-bit Windows 7 or Windows 7 itself. One workaround is to install the 64-bit version of the program if it is available.
If the program runs on Windows XP or Windows Vista, try launching the program in compatibility mode. Right-click Quicken 2000 and select “Properties”. In the “Properties” window, go to “Compatibility” tab then under “Compatibility mode” section, check “Run this program in compatibility mode for”. From the dropdown list, select either “Windows XP” or “Windows Vista”. Click “OK” then see if it works.
If this doesn’t work, uninstall it then download the program again. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your Quicken 2000 among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds.
This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then download Quicken 2000 Deluxe. See if this works.
