Lisa Larsen
Posted on - 12/10/2012
I had installed quicken in my pc which has windows XP. I did not open quicken for long time and my quicken shortcut was sent to unused desktop icon folder. Recently I cleaned up all unused desktop icons and now I am unable to find the way to open my quicken management tool. Please help me to restore quicken shortcut and open it again. Thanks.
How to restore quicken shortcut?
All you have to do is press your Start button at the desktop. From there, go to the search bar and then type quicken. Press enter to initiate the search then wait for several seconds. After the computer finds it, right click on your quicken application then click send to then click desktop. It will then create a shortcut of the application which will be found at your desktop.
Hi Lisa,
The fastest way to create an icon on your desktop is to open the program list by click on your start button drag the Quicken icon towards the desktop. It will automatically create a shortcut icon for you. You can actually do this technique to other items like folder and files in that way you can easily access it via the desktop.
