ashley.bila
40 points
Posted on - 09/11/2013
Hi All,
I am using Cool Edit Pro, a digital audio editing software in which I have made few changes in the setting, Please do let me know about How to restore settings in Cool Edit. Please help me.
Thank You,
Ashley Bila
To restore your settings in Cool Edit Pro, navigate to Options > Device Properties > Ext Controllers > Configure button dialog box for the Mackie controller. From there you can click on the “Reset To Default” button which will reset the settings to default.
Please note that this will discard any custom button settings that you may have set up.
If you have Cool Edit Pro and you want to restore the settings back to default, another way is to uninstall and reinstall. This will restore the application files back to the original version. Download the free version of Revo Uninstaller and install. Once installed, start Revo then select Cool Edit Pro among the applications and click “Uninstall.”
Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo then install the program back. If you no longer have the installer, download Cool Edit Pro 2.1 on TechSpot.com.
Adobe Audition is originally Cool Edit Pro. It is a digital audio workstation that was originally developed by Syntrillium Software and was later acquired by Adobe. In May 2003, Cool Edit Pro was purchased from Syntrillium and Adobe paid $16.5 million for it. Cool Edit Pro 2 supports Windows 98, Windows 98 Second Edition, Windows Millennium, Windows 2000, and Windows XP.
