How to Restore TSM Backup, in Case of TSM Server crashed ?
I am using TSM server 6.1 on Windows as backup on tape library. After using it as a backup, my TSM server crashed due to OS failure.
Now, how can I restore my data without TSM server from the Tape library? I urgently need it to provide the DBA.
Answered By 0 points N/A #92684
There are many data recovery software in the market. You can use one of them, but if you select TSM software to recover your data, then you need to install this software 1st,.  It will be helpful to you. Or you can just Install or repair your Operating System and if necessary,  update your current operating system.
If you repair your operating system then, just check it because repaired operating system might include some data too. And if you installed new operating system then, avoid overwriting data at the time of installation. It will restore some data. It will also help you to recover those lost data.
