How to restore wave file from mp3
Hello Techyv Experts,
How to restore wave file from mp3 without affecting the quality. If there is any freeware for that, Please suggest me the name.
Thanks & Regards,
Annie Brown
Thanks & Regards,
Annie Brown
Hi Annie
To restore your wave file download the Disk Internals Uneraser an easy to use software for restoring deleted multimedia files like Mp3, WAV, AVI and other music and movie files.
Or the Digital Media Recovery a powerful data recovery tool that recovers flash Drive, Mp3 Player, memory card, IPods, memory stick, digital cameras that are easy to use.
Boxoft MP3 to WAV Converter FreeWare
Boxoft MP3 to Wav converter is a simple, lightning-fast and powerful audio conversion tool that lets you to batch convert Audio .mp3 to high quality Wav audio formats on-the-fly, It is equipped with a standard audio compressed encoder, you can select bitrate settings and convert multiple files at once.
MP3 To Wav Decoder
http://download.cnet.com/s/mp3-to-wav-decoder/
This one-trick pony offers little extra functionality, but it does its job well enough and costs nothing. The application makes quick work of converting MP3s to uncompressed WAV files, and the interface is simple: just drag and drop files directly from Windows Explorer.
