How to restore windows 2003?
Dear,
It really depends on the cause of the problem. Like for example, if your system got infected by a virus and you are asking if there is a way of restoring it before the time it got infected, in this case, I’m not sure if there is a way of restoring it. With this kind of problem, the best solution is to do a full system scan on the whole machine using your antivirus.
With an infected system, restoring Windows to its previous state is not possible since it works mostly on software installation and other system events. But if the problem is different from a virus infection, its worth to try but it doesn’t guarantee that it will work. In Windows XP, the system can be restored to the previous state by clicking on Start, All Programs, Accessories, System Tools, and then System Restore. Try adopting this on your system since you are using Windows 2003.
And also, you can only use the System Restore if there is a Restore Point created. Otherwise, system restoration is not possible.
