How to restrict pornography on my pc
Hi dear people. I have 2 kids at home at age 8 and 6, they have their own pc and I observed both of them are hook online on the net all the time, I was surprised the'ye so very active on socila networking sites, specially facebook. I'm a little bit worried, maybe along the way they might encountered pornographic sites. I'm not  an online savvy, I need your help how I'm going to prevent my kids opening such sites. Thank you so much.
Best Answer by jamescarlo
Answered By 0 points N/A #112675
Please follow the following instructions in order to prevent pornography to be viewed. Note that this solution is for Internet Explorer only. I will suggest to keep installed only Internet Explorer on your kids computer and no other explorer.
1) Open Internet Explorer
2) Go to -> Tools -> Internet Options -> Content
3) Now you will see different categories there. Select "Sexual Material" category and check that the slider below is dragged to "None". This means that none of sexual material sites can be viewed.
4) Now finally click on "Enable". It will ask you for a supervisor password. Set a supervisor password there and you are done.
Whenever any pornographic site will be tried to open it will ask for the password. It will not open without the supervisor password.
Also in the list of allowed sites you can add sites for your kids which should be allowed without any password being asked. Thanks!!
Answered By 0 points N/A #112677
To Block the Pornography Websites:
Go to control Panle>Double click on Internet Options>Internet Properties window appears>Select Privacy>click Sites>type in the name of website>click Block.
You can repeat this process with as many website you wish to block.
