How to retrieve free website tabs code? I downloaded some tabs code in a zipped file or .rar file, I just want to know the proper way of extracting those files. Share with me your experiences regarding file extraction. I really need some guidance.
Timothy Raine.
Hi Timothy!
Well, I don't know which tabs codes you are referring to? guitar tabs?
But because your main intention here is about file extraction, I think I can help you with that. You can either:
1) Right Click on the file and click "Extract here."
This option will extract all of the contents of the compressed file to the same folder that holds that compressed file.
2) Double Click on the file and choose "Extract to "
This option will let you choose the destination folder of the content files after extraction.
Hope this can help you!
Jonn
