How to retrieve the wireless key in sun network
If the wireless key is lost then how can I get it back. Can anyone tell me how to retrieve the wireless key in sun network? Please answer.
A wireless network key or wireless key is a security feature that prevents unauthorized users from gaining access to a wireless network. It can be a simple password or a self-generated combination of numbers and letters. Most home routers allow users to easily configure a high degree of wireless security so there is no excuse for having an open network or an unsecured network.
A lost or forgotten wireless network key can be a problem, particularly on a network with many users and many wireless access points and repeaters. If you happen to have lost your wireless network key, there is still an option to recover it from your computer using WirelessKeyView v1.56 from NirSoft. WirelessKeyView recovers all wireless network security keys or passwords (WEP/WPA) stored in your computer by the “Wireless Zero Configuration” service of Windows XP or by the “WLAN AutoConfig” service of Windows Vista, Windows 7, Windows 8, and Windows Server 2008. It allows you to easily save all keys to text/html/xml file, or copy a single key to the clipboard. You can also export your wireless keys into a file and import these keys into another computer.
To download WirelessKeyView v1.56, you may visit NirSoft — WirelessKeyView v1.56 – Recover lost wireless network key.
Notifications
