How to retrieve data from a USB key??
I have a problem with my USB key, when i put it on my computer and i want to explore it, it gives a message to format.
I have a lot of data on this USB key and i don't want to lose. is there any method to retrieve this data before or after formatting??
Help me please.
Best Answer by brionas brain
Answered By 0 points N/A #106901
You can use USB Data Recovery software. This is very easy to use and you don't need any special skills to use it. Just follow the steps on recovering deleted data as stated below:
  • Connect the USB drive on the USB port on your computer.
  • Install the demo version and then run it.
  • The USB Data Recovery software will list the connected USB drive.
  • Select your USB disk drive and follow the on-screen instructions.
Answered By 25 points N/A #106903
I will give you advice on the problem that you are experiencing. Yes you can retrieve data before or after reformatting but it its a 50-50 chance if the file you saved on your flashdrive can be still recovered. Try putting your flashdrive on other ports of the computers or on other computers. You may try this programs on your file recovery before formatting your flashdrive  Pandora Recovery, Recuva  and use this program in formatting your flashdrive  HP USB Disk Storage Format Tool  and I will provide you the links on the programs
Pandora Recovery– https://www.pandorarecovery.com/
Recuva– http://www.piriform.com/recuva
HP USB Disk Storage Format Tool-  http://files.extremeoverclocking.com/file.php?f=197
Answered By 40 points N/A #106904
Dear Aldrin,
There are many software available on internet to recover deleted files from hard disk as well as from usb drive.
You can use many software to recover data files from usb drive.
But the usb drive has less chance to recover 100% accurate files.
I will suggest you to use Power Data Recovery.
You can download it from this link.
https://en.softonic.com/s/power-data-recovery-4.1.1-full
I hope it will help you.
Thanks
