How to Run CCleaner Automatically
I have installed CCleaner to my PC.
I need CCleaner to clean automatically after a predefined time.
How could I manage the setting needed to do it automatically?
To automatically run the CCleaner, follow the steps below:
1. Download and install the latest version of CCleaner from the link:
2. Run the program and then modify it accordingly and then select Options from the left pane.
3. On the Advanced tab, tick the Save all settings to INI files check box.
4. Click Start menu and then type Task Scheduler and press enter.
5. Click Action on the menu bar and then click Create Basic Task.
6. Just follow the onscreen instructions on how to create a task. Name the task and then add a description.
7. Select the days you will use the program. You can choose daily, weekly, monthly, etc.
8. Set the time that you wish to run CCleaner.
9. On the next page, select Start the program.
10. Click Browse and then go to the directory where you install CCleaner. Add /AUTO on the text field that is labeled as Add Arguments.
11. Verify on all the settings you made on the last portion and click the finish button.
You’ll need to decide which settings you want to run when CCleaner is run automatically… for instance, I’d look at whether or not you want to clean out your cookies or recent documents (which is a feature I use often, so I don’t want them cleaned out)
Next, take a trip over to Options Advanced and make sure that the “Save all settings to INI file” option is checked (it should be checked by default). This makes sure that whatever settings you’ve chosen are saved out to an INI file in the same directory.
Create the Scheduled Task in Windows 7 or Vista
Open up Task Scheduler by typing it into the Start menu search box, or browsing to Accessories System Tools.
Once you are there, click the link for “Create Basic Task” on the right-hand side.
Give the task a memorable name like “Run CCleaner”
Choose “Daily” or “Weekly”, depending on how often you want the task to run.
Now choose a time of the day that your computer is usually on, but you aren’t using it.
On the next screen, choose to “Start a program” and go to the next screen.
Now you’ll need to browse down to the CCleaner executable file, which is typically found in the following location, but could be elsewhere:
C:Program FilesCCleanerCCleaner.exe
Make sure to add the /AUTO switch to the “Add arguments” box.
On the Summary screen, make sure to click the box for “Open the Properties dialog” before clicking on the Finish button.
Now you’ll want to choose the option for “Run with highest privileges”, so that the task will automatically run with administrator privileges.
Optional: You can also take a look at the Conditions tab, and choose the option to start the task only when the computer is idle for a certain amount of minutes.
You should notice the “Wake the computer to run this task” option as well… if you usually put your computer into Sleep mode, you can check that box so that the computer will wake up to run CCleaner.
You can test out the task by right-clicking on the item in the list, and choose Run. CCleaner should run silently in the background.
You can look around at some of the other options… for instance some people run CCleaner a couple times a day (although that seems a little excessive to me… once a week would probably be good enough)
Create the Scheduled Task in Windows XP
If you are using Windows XP, there is a whole different wizard you’ll have to go through… open up Scheduled Tasks in Control Panel or from the Start Menu’s Accessories System Tools section, and then click on “Add Scheduled Task”
If you’ve installed CCleaner using the regular installer, you should see it in the list. If not, then you’ll have to browse down to the location of the file.
Then you’ll want to give the task a helpful name, and choose “Daily” or “Weekly”, depending on how often you want to run it.
Now choose a time of the day that your computer will be on, but you won’t be using it, like 1AM (or if you are like me, 8AM)
You’ll be asked to enter the password for your user account.
Make sure to check the box for “Open advanced properties” and then click on the Finish button.
Now you’ll want to modify the Run command to include the /AUTO switch at the end. Make sure to put a space between.
If you look at the Settings tab, you’ll see the options to only start the task if the computer is idle, and also the same option to “Wake the computer to run this task”, which is useful if you usually put your computer into standby mode when you aren’t using it.
You can test out your scheduled task by right-clicking on it and choosing Run. CCleaner should open and run in the background.
Notifications
