How to run the dual webcam on the visual basic program?
Hi, I need to plug in two cameras on some security software program. Has any way that I can run both the cameras at the same time?
Hello Hardin,
I have a solution for your problem. If you want to plug in more than one camera on your PC than you should use the program called Dorgem. http://dorgem.sourceforge.net/ . The good point for this program is that is very easy for using it, but just in case you do not know how to use it here is a simple help. https://www.simplehelp.net/2006/09/27/how-to-use-your-pc-and-webcam-as-a-motion-detecting-and-recording-security-camera/ . This will help you to detect and record everything around your object.
