How to run Informix file?
I was working in a Software Company.
I need to learn Informix 4GL according to my Project Requirement. I would like to know how we can execute the .per files?
Can you tell me the procedure to execute those files.
I have read your problem and a best solution for your problem which I will recommend you is,
This link will helps you, in order to get the knowledge and updates about the infomix file. The basic and core purpose of the link is to get the complete idea about the infomix file operating procedure and the core requirements which it needs.
http://www-01.ibm.com/support/docview.wss?uid=swg21424021
Here you found the ways to run Informix file. And as well as the latest versions and update versions about the infomix files also.
Hope so you will get the solution from my suggestion.
Good luck for your future working.
