Hello Experts,
How to run jar file on iPad? What kind of application that I need to download in my iPad just to run and open a jar file? Give me some ways or alternative solution to this kind of situation for me to figure it out the best thing to do. Share with me your experiences on iPad and running jar files.
Thank you.
It depends on  which folder you have kept your jar file. You can re-download the jar file and open in download folder or from main hard drive folder. Alternatively  shift it to my apps folder. Here is also a link on jar files tutorials which will assist u; https://docs.oracle.com/javase/tutorial/deployment/jar/. Check  also the unix forum.
Hello Mellisa,
What type of files are inside the Jar? But i believe you can open it with iFile, or you can open the jar using winrar and copy the class files and read the files. I hope this might help you.
If you want to download jar file apps for iPad or iPhone you can download it from the link given below,
https://ios.lisisoft.com/s/jar-file-player.html
Just go to the website, select your apps and download it.
Thanks
