Greg Lewis
40 points
Posted on - 10/26/2012
I have many SQL queries I have no SQL install in my computer I want to use online query editor to run my queries Is it possible I run my queries by online if it then how I use it please tell me so that my problem will solve.
How run query in Online query editor
Write queries and build it online using ideone tool searched so far go to site then write your query there and check it another tool sql web query and download it from codeplex it is low in memory size so can install it in few seconds ideone tool gives more features with number of developing codes can execute online for more information refer stack overflow and search your query get results by professionals.
Hope these shall helps you
Thanks
