Arabella
10 points
Posted on - 09/09/2016
Hi. Since I do not have an IT background and because I want to run the remote desktop, I would like to know how to run remote desktop on Windows 8. Please reply ASAP as it is quite urgent. Thanks in advance.
How To Run Remote Desktop On Windows 8 Using Some Simple Steps
Hi. To learn how to run remote desktop on Windows 8, click on the start menu and then in the search box, type Remote and select the remote desktop connection. Then, on the remote desktop connection screen, select show options. Connect your computer to another computer by typing in the address for that computer on the network or you can click on open in case the computer connection is saved already.
Then, click on display and select the colour quality which you desire. Next, select the local resources and click the audio settings in addition to the local devices to which you want access. Select the experience option and the quality that you want to in the connection. Connect to the remote desktop by clicking on the connect option. Hope we helped.
