How safe is buying laptop hardware Online?
How safe is buying laptop hardware online and where should i buy it? I want to upgrade some of the hardware of my laptop. Please tell me the best solution and best place. Please help!
Dear,
Please Buy directly from this site.
Some Sites are given below ;
(http://www.dell.com/en-us/ ; https://www.ibm.com/in-en/ ; https://store.hp.com/us/en ; www.hp.com ; http://www.toshiba.com/tai/ )
Thanks
Since you are upgrading your laptop computer's components, it would be best if you purchase from the laptop manufacturer's website. It should be safe when you purchase from their website, especially if they're one of the bigger players in the computer industry. They should have enough security measures implemented with the online purchases to keep your information secured. If you are quite away though about what parts to use and can check compatibility yourself, you can head to other online stores like newegg.com and check what they have for sale. Just make sure that when you choose where you'll buy, the website is reputable so that your information is kept secured.
Notifications
