How to protect my PC from Pen Drive virus
Hi Experts,
I have a big problem. My PC is attacked by virus. It is a big problem for me as the source of this virus is the pen drive. Please tell me the way to save my PC from pen drive virus.
Thank you.
Hi Experts,
Thank you.
Make sure you have a strong Antivirus running on your system and it should be up to date. Every time you are using your pen drive, ensure that you scan it before you open it. Also ensure that your firewall is ON.
You can also get a software called 'Malware-Bytes Antimalware' to work hand in hand with the Antivirus.
Another thing to do is to be careful about using your pen drive on other people’s systems that might be infected then using it on your computer. Every time you use the pen drive on another system, be sure to scan before you use it on your computer. Also scan it every time you use to carry stuff from the internet.
Hope this helps.
____
Lee Hung.
Due to the autorun feature of Windows serial system, like CDROM autoplay, most of the pen drive viruses create an autorun.inf file in the root of the pen drive folder to load automatically when the pen drive is inserted in the system
