How to safely install naruto rpg fighting? Me and my friends are collecting naruto games and magazines, we never fail to get the best copy of those magazines. I just start to collect naruto games, how to safely install naruto rpg fighting? Is it compatible with my Windows Xp operating system? Will it possibly run in a 2.1 GHz hp Compaq laptop?
Rebecca Green.
Hi there Rebecca:
Downloading applications is risky if you’re careless. What do I mean about the term ‘careless’? This means you are downloading applications from different sites without an Antivirus installed in your computer, or you have one but wasn’t able to update.
To be safer from downloading (in the presence of your antivirus), you have to scan the file/application when the download is complete, or before you install it into your computer.
Yes. The specification you stated is compatible for this game. Here’s the link. https://en.softonic.com/s/naruto-games/windows-xp Enjoy it!
Best regards,
Greetings!
Just make sure that your copy is original and legit, not pirated, doesn't virus, and is not corrupt. Then just follow the instructions in installing. Here are the requirements in installing it:
Operating System: Windows XP|Vista|Windows 7
Processor: Should be 2.5 GHz
Memory: Atleast 1Gb
Video: GE Force 6800, ATI XI300 or higher
Free Space on Disk: 7Gb
Sound: Direct 9.0c – compatible sound card
Controls: Keyboard, mouse (for better game play, use gamepad)
Good luck! Regards!
