How to save battery life
Hey, Are there any tips through which I can save my battery life of iPhone during traveling. I most of the time travel all over U.S.A, I loose charging frequently in IPhone. I need a solution for this.
You need to disable the location services, Wireless and Bluetooth connection if you are not using it. Ensure that the auto-brightness is set to on. This will correct thebrightness on your display based on the lighting of the present environment. This will let the display from continuously running bright. Just simply go to the Settings and select Brightness.
Dear,
IPhone is the more powerful than any other cell or smart phone. So it is very important to save its battery life. Here are some tips to you extend battery life. You can reduce the brightness of screen, keep Bluetooth and WiFi connection off, turn off 3G, less wake and sleep your iPhone.
Thank You.
