How to Save FaceBook pictures on Galaxy Exhilarate
I currently used a Samsung Galaxy Exhilarate phone. I used this to access my Facebook account. My question is how can I save the pictures from my message inbox and from my album to my phone? I can’t find any Save or download button when opening any images. I need some help.
Best Answer by marsh watson
Answered By 0 points N/A #108535
It’s been little difficult to save photos from Facebook to Galaxy Exhilarate but If you want to save Facebook photos on your Galaxy Exhilarate, you can try these steps-
  1. Tap on the photo-then from the menu select share as-
  2. Then select photo editor-then select rotate
  3. Then done and save.
Hope that will work for you.
Answered By 0 points N/A #108537
Hi, Goan01
Go to your phone Facebook. Then login your Facebook. Then you do this that.
At first you click the profile then click the change picture option.
Then select your favorite picture.  Then your picture will be select.
So I  hope that your problem has solved.
Answered By 0 points N/A #108539
Solution 1: View the picture in full screen mode then use screen capture to save the image. For screen capture use Home+Power button.
Solution 2: Long press the message icon on the picture and then use share to edit the picture and save it.
Solution 3: You can have any facebook picture to set as a wallpaper or contacts picture. Then use this picture to store in your phone.
