anonymous
7060 points
Posted on - 06/20/2011
How do I save a lotus notes email to my workstation?
Any file format will be fine ,as long as it will still look as it is in the email. Not just plain text ,but everything in it, sender, recipient, images, subject and content of mail, attachment images, date and time of mail.
Better if file format is commonly used. I need this to save some email threads for documentation purposes.
Please help.
oswald
How to Save Lotus Notes Email
Unfortunately there is no such option provided by Notes to save your individual HTML messages. But don’t be afraid there are some other options you can try to save messages in your workstation.
1. Go to File > Export . Here you can save your emails as .txt or .rtf format. The formatting is frequently maintained.
2. Outlook express would allow you to open (MIME only) messages in eml format, so you can save emails in eml format.
3. You can save all the attachments and formatting as it is.
Step 1: Go to View > Show > Page Source
Step2: Copy the content of the page source into the clipboard
Step3: Go to any text editor and Paste it and save with the file extension .eml
Lotus Notes emails cannot be saved, straightforwardly, into your local computer still maintaining its format.
But here are some options you can do to save those emails.
You can "Archive" your messages and save it on your local computer. But with this, you would still be needing access to lotus notes.
You can export your lotus notes email as txt or rtf document. With this, format of your emails are not maintained and also the attachments would not be included.
You can save emails as eml messages and open it using Outlook Express.
