How To Save A Pdf To Word Document By Different Methods?
I am doing a project regarding my business. I was doing it in a PDF file, but then I realized I was doing it all wrong. How can I save a PDF as a Word document?
We can open any PDF file as a Word document by copying the content from it. We need to click right on the file and then choose the option of Open. Now you can browse through files and copy images, text, and diagram.
Method 1-
Step 1: Open Acrobat.
Step 2: Select My Computer after choosing Storage.
Step 3: Navigate to the PDF file, and click Open.
Step 4: Select Summary.pdf to convert.
Step 5: In the tools, Panel, click Export and then Export.
Step 6: Next to the document type, select Settings icon and after finishing click OK.
Step 7: Click on Choose a Different Folder to export file, name it and then press OK.
Step 8: Open the document in Word. Method 2- Using Google Docs.
Step 1: Go to Google Docs after signing it.
Step 2: Select a PDF file to upload it.
Step 3: Go to Google Drive, right click on the docuement.
Step 4: Select Open with and then Google Docs.
Step 5: In the upper left, select File and then Download as and press Microsoft Word (docx).
Unfortunately, you cannot save your PDF file as Microsoft Office Word but you can convert your file from the PDF file format to Microsoft Office Word DOCX format (.docx). First, complete your PDF file and continue saving it in PDF format. Once your PDF file is saved, open your web browser and go to Convert your documents to DOCX. Upload your PDF file and convert it into DOCX format.
You will be able to download the converted file immediately after the conversion. You can upload your file to the page in different ways. You can select your file directly from your computer. Another way is to upload your file to Google Drive or Dropbox and the converter can fetch the file from there.
Notifications
