Every time I insert my micro SD card and start my camera, a message appears, "insert SD card". Why does this message appear? What can be done to resolve this. Moreover, until that problem is solved, is there any way I can save pictures in internal storage? If so, how? What settings will I have to change? I am using iPhone 3.
How to save pics in internal storage
Hi !
An original iPhone 3 from Apple doesn't have a slot to insert micro card SD. It's have only the internal memory which can be started from 4GBÂ up 32GB on the new iPhone. It al the main battery cannot be removed which guarantee to the users that it will never block.
For your iPhone 3 you have to go to the main menu => settings => memory settings => set the intern memory for storing first.
It also might be a problem with software, reset to the factory settings or reinstall your software.
