How do i save you tube videos on my computer?
lee hung
75 points
How to save youtube videos is it possible?
In what reason why you want to save youtube videos on the computer? If you just view it in your PC or Laptop then you canÂ
just simple download converter on the internet try to search on YAHOO or GOOGLE in any search engine, there are many free softwares available on the internet for this. Always remember of the files extensions. Youtube videos are commonly .wvsÂ
which directly play videos in any WINDOWS operating system. If you are planning to view videos on the TV or DVD then youÂ
probably need a software converter that will translate your .wvs to mpeg in order to play it on the TV or DVD. If you don'tÂ
have a youtube converter on your computer you can always check your browser history once you open a video it remains thereÂ
until you erase it.
Thanks,
Tony Stevenson
Yes it very possible win Edwin to down lord a video and save it on your computer what you need to do first and for most is to down lord a YouTube down loader so when you play a particular clip on you to save you will have to past that particular URL in the downloader and  you will be in position to store you particular clip of choice and on your computer. On that very downloader  you can convert that particular video to even fit your phone memory in  case you would like to have it on your phone hope it helps you
