How to scale the ui in lion?
I would like to ask you guys about on how to scale the UI in lion? I am using a mac OS x lion operating system. And i just want to know how this application in lion works. Tell me more about it if you had an experience with this share it with me.
Best Answer by Julinee James
Answered By 10 points N/A #145593
It is possible to scale the user interface in OS x lion. Apple provided the option to scale the user interface in OS x lion and higher. To use this function follow the steps below:
1. You could use the zoom in button that is available in the toolbar.
2. In the settings window you can change the aspect ratio of the screen to adjust to your preferable resolution.
3. Scaling of the user interface is a unique option and you have to take extreme caution while changing the settings.
4. Remember to change back to the default settings when you do not need scaling.
5. You could also use the command and + button to scale the user interface.
Hope this information helps you.
Answered By 0 points N/A #145595
There may b various process to scale ui in lion but you can try the easiest way which is,
double the scale using the HiDPI modes which are designed for future high ppi screens and aren't really practical for current displays.
This process can help you to scale up.
