How scan ps3 from virus
Hi guys,
I just wonder that is it possible for a ps3 attacked by virus. How scan ps3 from virus? In addition, how can we protect ps3 from virus attacking?
Thanks
Hi guys,
Thanks
Yes, it is possible no doubt about it because everything which connects to the internet can attacked by virus. However never heard virus attacks on ps3 but be pre cautious about it. The only way to remove virus from your system is going to the Settings then system settings. Make the page down you will see Restore ps3 system and it will restore and delete everything but first you might save your data on external hardisk or on SD memory card. The only protection is to download anything just download it from sony web sites it will keep you safe and protected.  Here is the URL for ps3 scan software easy to use just download it.
