From time to time, we find ourselves loading a long webpage and at the same time, we want to screenshoot it. It is difficult to screenshot since it is a large page and need to screenshot multiple times and later merge them to one single image.
So, is there a special web browser or a toola that allows to screen shot a single long webpage into a image file and have the option to control the quality of the image?
How to screenshoot whole page?
Is it possible to capture images showing on your computer screen. We need this to capture different screen shots showing on our display one of the best way to taking screen shot is to press *fn + print screen* if you're using laptop or just simple *print screen* on keyboard. After this, press *Control + c* key and open paint from start menu, then in paint press *Control + v* to paste the screen shot, save it in desired folder.
Another way of taking the full picture of your screen is using corn extension named *Full page screen capture* Hope it will help.
Most of the screenshot tools cannot take a whole web page screenshot. But there are some browsers and some tools that make your works easy. First, if you don't have google chrome then you download it and open.And click here. It is a google chrome extension that can take a full web page screenshot and convert your webpage into an image. It works easily,
