Hi techy. I have presentation of power point ptt I want to convert it to dvd type like commercial.
How to search ppt to dvd type commercial? It is possible to be done? Please help me I really need it. Thank you so much techy.
Hi, Elias.
There are lots of solutions, hope some will work for you. You can install the PowerPoint to video converter with the following link: https://support.office.com/en-us/article/turn-your-presentation-into-a-video-c140551f-cb37-4818-b5d4-3e30815c3e83. Select an output video format you need and if you want, you can also customize video profile parameters. Then click ''Start'' to convert your presentation to video.
The second solution to make your task is to download and install Camtasia studio on your local computer.
The third way is to create a PowerPoint video with Adobe Captivate.
You can also try it with Windows Movie Maker (which is free for Windows XP or Vista users), then Microsoft Photo Story 3 (for Windows XP Users), Microsoft PowerPoint with his option Save As Video and Quick Time Movie (for Mac PowerPoint). If you are willing to try different options on this link: http://www.dvd-ppt-slideshow.com/blog/7-best-ways-to-convert-powerpoint-presentations-to-video/ you have described steps for each solution.
Enjoy your work.
