How to Secure Wireless Internet and Prevent Unauthorized Access?
Nowadays wireless password are easily accessed when not secured.
Can someone here give me some ideas to prevent such incident?
Experts need help to get with this.
Thanks so much.
Thanks so much.
Hello Petrusic,
I’m agreed with you. It’s a worse headache for everyone. We can take some primary measure to prevent such incident. It’d be easy if we go step by step :
1. First turn on WEP/WPA(Wi-Fi protected access) on your device.
2. If you are using another device like router, Xbox then follows the same procedure for these devices also.
3. Don’t forget to turn on your firewall and make sure that you are using updated antivirus and antispyware.
Now your password wireless is much protected than before.
