How to select best link list interview questions ?
Hi, I need link list interview questions. Can anyone tell me which method should follow in order to select best link list interview questions ?
You can start with the basic linked list questions like “what is circular linked list” , ”How to insert in the middle, beginning or in the end of a linked list ” , ”How to check whether a linked list is circular”. Then you should go through the complicated questions such as “How to detect a loop in the linked list”. ”How to compare two linked lists” You can also seek for definitions such as “doubly linked list”, ”Generic linked list ” etc.
Thanks
Hi Lindakcarico!
I suggest that you search at Google the keyword “coding interview questions" and from there it will give you a lot of options to choose from. I also recommend that you should use the "analysis method" since this method will give you a lot of pointer operations that are necessary to solve problems related to different link lists.
Many candidates are prone to make mistakes on pointer operations and interviewers knew that. And so interviewers like problems of the linked list to qualify candidates' programming abilities. I hope this would help you!
