How to select right Anti Virus software
How to make desktop free from Virus attachments? We use pen Drives and Internet downloading application frequently. We can define safe sites for virus free downloading. So many free antivirus software's are not giving good performance. It is compulsory to use License version Anti Virus.
Please suggest good anti virus for Desktop usage.
Best Answer by Scott Bull
Answered By 0 points N/A #111057
The purpose of antivirus software is not only to remove malware infections, but to actually prevent the infections. There are certain freeware anti-virus programs that you can safely install on your computer. McAfee and Norton are the two most common software in the security industry. Anti-virus programs can greatly reduce the risk of virus infection. Additional security you can use to protect your computer is using firewall, password protected WIFI, and an up to date antivirus system. In addition, self-monitoring is the key. Stay away from untrusted websites & only download files from website you know and trust.Some of the additional list of popular antivirus and security software are AVG, BitDefender, Avira, Trend Micro and ZoneAlarm.
Answered By 0 points N/A #111059
Hi Kartik,
Choosing the right antivirus is a bit difficult one. One can select the antivirus based on so many factors such as ranking, reviews, and also based on his/her applications. If the machine is always connected to the Internet, along with the antivirus, it is mandatory to keep a anti-spyware. A Spyware is a software or a program that works from a computer to secretly collect the information about the users of a system and distribute this data to the interested third parties and related advertising agents.
There are many free antivirus and free anti-spyware available. One of the most common among them is Avast Antivirus and Malware-Bytes. They can be installed and used for a particular period of time free of cost. If you are very keen on selecting the Antivirus, you can have a look at the following website before choosing:
https://www.pcworld.com/article/2050339/security/build-the-best-free-pc-security-suite.html
Hope this helps.
BR,
Sharon
Answered By 0 points N/A #111060
At first you have to choice your basic Anti virus to use in your Computer. Install on Desktop. Check on your PC have virus or not. And Anti virus you selected must be well application and renovate from recognize software sites. Pick up the update daily on Internet connection.
1. If you are not save  your Anti virus on Desktop then find on Start menu and all programs.
2.Then find menu Bar select the Scan option and click on the folder to scan you like.
3. You will not select additional folder to Scan.
4.If found some Virus you  have to delete this which asked to you.
If  you are not remove from your problem then go to the menu and Scan your whole system at first time.
