How to send big files lotus note securely?
I am having issues on sending large files through Lotus Notes.
It always tells me that I cannot send more than 50MB of file size.
Is it possible to send a large file through Lotus Notes?
How can I do that properly?
I need the a step-by-step guide on sending large file through Lotus Notes.
Answered By 0 points N/A #183955
Hi Ian,
You can set the size allowed on your server by going to the Mail settings – Select Configuration – Message settings – Router Restrictions and then look for Maximum Message size then you can have it changed to KB you can try putting 10000KB equivalent to 10MB.
OR
You can set the message size under restrictions:
Click Restrictions then Send all messages as low priority then change the size to : 10000KB. The changes made will be delivered 12 midnight.
Hope this can help you.
