How to Send a Fax Message Online
There is lot of online faxing services and most of them offer a few faxes for free. If you need more you must signup for paid service. If you need to send one or two faxes per day, these services are good choice.
Some of them are FaxZero, Pamfax, MyFax, Popfax.
Before choosing a service, make sure you have read their Frequently Asked Questions and/or Terms Of Service , some services are not available in all countries for free and you need to find out which one is the best for you.
In globally, principle is the same. You can send one or two faxes per day for free after signing up with your e-mail. You need to save the document you are faxing in DOC or PDF format, or to type fax content in online editor. Fill in sender/receiver data and that is it. Some services will send you e-mail because you need to confirm fax sending.
Sending fax messages is usually done using a fax machine. But if you don’t have a fax machine and you still want to send a fax message, you can still do it through the internet. But to do this you need to buy fax software and a fax modem. Here’s how to check if you already have a fax modem on your computer:
If you are using Windows Vista Premium and or Business edition, you don’t need to buy a separate fax software because “Windows Fax and Scan” is already integrated with the operating system.
Notifications
