How To Send A Fax From A PC Without A Fax Machine.
In this generation of Internet, most of the people don’t have a fax machine. It is important to know how to fax directly from the computer, to save the space. how to send a fax from a PC?
1) Go to start and select Windows fax and scan.
2) Click on New Fax.
3) Enter the area code and the subject.
4) Click on Insert and attach the file you want to fax.
5) When you are done, click Send.
6) You have sent the fax successfully.
USING GMAIL
1) Sign in your Gmail account.
2) Compose a new email.
3) Write the [email protected] in the place of recipient name.
4) Enter the subject of the Fax.
5) Go to www.faxfromgmail.com
6) Click on any service and fax from your PC.
