How to send text from my Sony Ericsson cellphone through my computer
I have a sony ericsson phone W200i.
My work requires me to SMS several people throughout the day.   It is getting troublesome texting from the keypad as my phone is very slow.
Can you recommend a software that will let me send text using my computer keyboard?  I tried the software that came in the cd with my phone but it doesn't have anything that can help.
I am using Windows by the way.
Thank you in advance.
Best Answer by Ray_Palmer
Answered By 0 points N/A #111920
There's a freeware application called MyPhoneExplorer which lets you connect your phone to your PC via bluetooth or USB cable.  With it, you can organize your phones contacts, calendar, notes, profiles and other aspects of your phone.  Most of all, it lets you send and receive text messages to and from your phone and you can read and reply to it through your computer.
It runs in Windows 2000 and Windows XP.  For Windows Vista or Windows 7, you might need to look for updated USB drivers especially if your phone is an old model.
Another software similar to MyPhoneExplorer is FMAgent.  But it is already discontinued.  It is also free and works well if you have much older Sony Ericsson phones like the T230.
Answered By 0 points N/A #111921
Dear MikoMido,
Yeah you can do this by software. If you face problem to write from your mobile phone you can write text file from computer after that transfer the text file to mobile phone. File transfer from computer to mobile can be done by using data cable or Bluetooth. You can also use PC suite software for your mobile.
Thanks and Regards
Louis.
