murz furby
10 points
Posted on - 01/31/2013
How to send textpad to OneNote app? Textpad is my favorite text editor, I want to implement it in Onenote iPhone App. But I cannot send textpad to onenote. Is there any proper working method to do so?
How to send textpad editor to OneNote app ?
I'm afraid there is no such option. You can always send text written using textpad into your OneNote application. But if you want to send an installation file into OneNote then you should make archiving and attach that archive to OneNote application. Sorry, but there is no other way doing this. I hope I helped.
There is no straightforward solution for sending documents you saved in Textpad to OneNote app, however, there is a workaround. You can upload the file to the internet and then download it to your phone to open with OneNote. This can be done either by attaching the file to an email that you then send to yourself or uploading it to a file hosting site, such as pastebin.com
