How to set up Adblock with Google Chrome?
I am using Anchorfree Hotspot Shield VPN. I am extremely annoyed with ads popping-up while browsing. I am using Google Chrome. I recently installed Adblock to eliminate the ads. I did set some restrictions but there are still some ads that remain. Can someone give me a tutorial for Adblock on Google Chrome?
Best Answer by zakaria b
Answered By 0 points N/A #128646
Hi Alvin,
Cramer's for Google Chrome does not currently feature support for add-ons or extensions like "Adblock Plus", but Chrome will definitely support add-ons/extensions in the future. "Adblock Plus" or something like it will be available for use with Chrome. I advise you to use Mozilla Firefox 5. It's fast and supports Adblock.
Answered By 0 points N/A #128647
Just simply installing the Chromium on Ubuntu/ or Debian system you must update daily the version. Makes sure to add Ubuntu/Deb repository to apt. Open/etc/apt/source list
Sudo gedit /etc/apt/sources. list and add the line to the file and you must save the file.
Deb Download Link. Just enable the Plugins and the extensions, and user scripts in Chromium just simply start Chromium you must create a Launcher to open the Gedit and makes sure the Chromium enable the extension to install. Crux plugins in the right away.
