Hallo,
I am trying to set up and use the most up-to-date version of Firefox. However, I can only position the handler four common, but not the procedure entry point. How do I go about fixing this error? I am not good with such stuff.
Thanks a lot.
How to set up and use the most up-to-date version of Firefox
You only need to download new version of Firefox and after Firefox download JAVA 1.6.0.21 plugin for your latest Firefox, it will boost your 'Fire Fox” speed and handling. Install and update your browser with newest “Adobe Flash Player” plugin which will provide you the best flash player experience on Firefox browser.
After installing of the essential plugins your browser will be restart and after restarting, your browser will work properly.
janchan
Hello Janice,
If you are using Windows XP, then the problem is caused by the dwmapi.dll. You need to search the dwmapi.dll located in the win32 folder. Make a copy of it in a different folder (for backup), then delete it. Try installing the latest Firefox version again, it should work without the error.
