How To Set Up A Database In Access
When you close a database without closing the access, backstage view appears. This is the place from where you can create a new database. How to set up a database in access?
HOW TO CREATE A DATABASE USING TEMPLATE
Template consists of all the tables, reports, forms etc. These can be used to create a database.
1) Open a database. Go to the File menu and close the database.
2) Backstage view will appear in another tab.
3) Select the templates according to your convenience.
4) You can change your file name from the File Name box.
5) From the file menu click create.
6) This will start the creation with the template chosen.
7) To write data, click on the first cell and type.
CREATE DATABASE WITHOUT TEMPLATE
You can build your own tables, reports, forms etc.
1) Go to the file menu
2) Select new.
3) Click on Blank Database.
4) Enter a file name in the FileName box.
5) You can change the location of the file by click on Browse for a location to put your database.
6) Click on create.
HOW TO OPEN AN EXISTING DATABASE
1) Go to file menu and select open.
2) Browse the database.
