David Shawn 10 points N/APosted on - 08/29/2012
I have just purchased an iPhone 4. I want to set up the dual time zone display on my iPhone. I don't know how to do it. I need it badly as I travel a lot. So please tell me how to set up dual time zone display on my iPhone.
First, go to the Utilities folder and go to Clock application. And you can add second Clock. (By default Clock application in the Utilities folder)
You can add a different clock to your home screen using Clockify. It`s got ability to add different clock to the Clock app on the home screen. You can get more information from below link,
You can set multiple time zones on and iOS device. To do so simply go to the Clock application and simply add another clock. Also LoversClock app might be just the right for you. It supports multiple time zones ant also puts them into status bar. LoversClock can be found on the following link LoversClock iOS application download.
If you have an iPhone and you want to see two time zones on your phone, just add a second clock to your existing clock. To do this, you need to add a new city to the World Clock on your phone. On your iPhone, launch the Clock app from the Home screen then go to “World Clock” tab, the globe in the bottom left corner of the screen.
World Clock tab
Next, click on the plus sign (+) on the upper right corner of the screen to add a city. Next, tap on the search bar then type the name of the city you want. Also, you can scroll down the list to find the name of the city manually. Next, tap on the name of the city.
The new clock will now be displayed on the main screen in the World Clock.
1....
