How to set-up an email on Samsung Galaxy Tab GT-P100
Hello everyone. I have just bought a GT-P100 Samsung Galaxy Tab. I just want to know how to configure or set-up an exchange work email on it. Thank you and your advise will be appreciated.
Dear,
To set an Email account you have to follow the step:
1. In Menu mode, select Email.
2. Enter your email address and password.
3. Select next (for general email accounts) or Manual setup (for other company email accounts).
4. Follow the on-screen instruction.
5. To add mire email accounts, press → Account manager → Add account and repeat steps 2-4 above.
When you are finished setting up the email account, the email messages are downloaded to your device. If you have created more than two accounts, you can switch between email accounts; Select a domain logo at the top left lf the screen and select one you want to retrieve messages from.
Thank you.
Follow these steps on your device to set up email:
1) Start your device.
2) Go to email app by browsing the installed apps in the menu.
3) Type the email address and password for your account.
4) Touch the next button and set up your account settings.
5) Click ok and you have successfully setup your email.
Hope this helps
You are probably referring to the P1000 model not P100. Anyway, check these specifications. The Samsung Galaxy Tab P1000 is a discontinued 3G tablet operating on 2G and 3G network bands using GSM and HSPA technologies. It was announced to the public on September 2010 and released on October 2010. It measures 190.1 x 120.5 x 12 millimeters and weighs 380 grams.
It supports mini-SIM card. It has TFT capacitive touchscreen display with 16M colors at 600 x 1024 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass with TouchWiz UI. It runs on Android 2.2 Froyo upgradable to Android 2.3 Gingerbread powered by Hummingbird chipset, 1.0 GHz Cortex-A8 processor, and PowerVR SGX540 GPU. It supports microSD expandable up to 32 GB.
It runs on 512 MB RAM with internal storage available in 16 GB and 32 GB capacities. The primary camera supports 3.15 megapixels with LED flash and autofocus featuring geo-tagging and supports video in 480p at 30 fps. The secondary camera supports 1.3 megapixels. It has 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with hotspot support, Bluetooth 3.0 with A2DP support, GPS with A-GPS support, and USB 2.0.
It doesn’t have stereo FM radio. It has built-in accelerometer, gyro, and compass sensors. The preinstalled web browser supports HTML with Adobe Flash support. Java is supported via Java MIDP emulator. It runs on non-removable Li-Ion 4000 mAh battery with talk time up to 28 hours on 2G and 25 hours 30 minutes on 3G. It is available in black and gray colors.
Notifications
