How to set Filezilla clear history auto?
Is there a way to set Filezilla clear history auto mode? What I want to happen is everytime I close the program all the FTP sites I access will be deleted. Some of the FTP sites I am managing contain sensitive information. But I am sharing a computer with two other IT guys.
Best Answer by Goram Ian
Answered By 5 points N/A #192360
I don't think there's an auto delete history feature for Filezilla, it may be because the developer doesn't want to encourage the use of quickconnect for things it wasn't intended for. But it has a feature which is Site Manager you can try that out.
Answered By 0 points N/A #192362
Hi King!
I read the version history of Filezilla and I can’t find a feature that they have an auto delete after closing the program. I think you should delete it manually. To have further information you can visit their website.
https://filezilla-project.org/versions.php?type=client
Thank You!
Answered By 60 points N/A #192363
Hi, King Lopezs
There are many solutions in your problem. You can simply clear the history on the upper side bar or you can uninstall the software and install it if you need it again. You're not the only one who experience this problem. If you want to have more tips or ways on securing your privacy with Filezilla, you can click the link below and read the posts. It may help you a lot.
