How To Set Up Group Policy Auto logoff In Windows 7?
I want to setup a group policy that logs off the users system when it is inactive for long time. How to set up such a group policy auto logoff.
Hello, I am afraid that setting up auto log off in a group policy is not very possible. But instead you can setup auto log off for each user by using the registry method.
Step 1: Press Ctrl+R and type “Regedit”
Step 2: Move to the following place
HKEY_Local_Machine–>Software–>Microsoft–>Windows NT–>CurrentVersion–>niFileMappings–>Control.ini
For 64-bit users use the other path as mentioned below
HKEY_Local_Machine–>Software–>Wow6432Node–>Microsoft->Windows NT–>CurrentVersion–>IniFileMappings–>Control.ini
Step 3: Right click control.ini and select permissions.
Step 4: Add Everyone to give permissions for the system to logoff.
Step 5: Set the Screen Saver “Logoff Screen Saver” and press OK button
