How to set up hosted exchange Mac mail
Hello friends…I need to have hosted exchange mac mail and I want to know the step-by-step guide to do this. I don’t have full idea on how to do this but I want to try through your help. Ready to follow your instructions and if I got problem I’ll get back to you to ask more. Thanks for the help.
Answered By 0 points N/A #163926
Hi Louise,
This is the procedure through Mac Mail in setting a hosted exchange account:
-First is run Mac Mail
-Click Mail in the Menu Bar then select Preferences.
-From the tab buttons, click Account. Then, at the bottom part of the Preference Window, click the + button (add new email account)
-Fill up the information that will be asked in the new email account wizard.
-Then select Continue button. You will be asked for some certificate. Then click connect. Then another screen will appear. From Account Type selection, select Exchange 2007. Another screen will appear and need to name the account when it showed up. Then, the server in incoming mail is re001.mail.microsoftonline.com
(Fill up the required information given like email and password)
-Then in the screen, check/enable this two:
>Address Book Contact
>iCal calendar
-After filling up the information properly, Account Summary Screen will show. Check if SSL is enabled for incoming and outgoing servers. Enable Take Account Online then select create.
-That's it! If you are not automatically receiving incoming emails, then click the Get Mail button to download it.
