How to set up iPhone SMS privacy?
Hello friends,
How to set up iPhone SMS privacy? I would like to put a password in my iPhone Inbox which my SMS was stored. There is some important conversation which is confidential and I don’t want anybody to invade that privacy. If there are some ways to make this happen, please let me know.
Thanks and Regards,
Madison.
Best Answer by Kamil Juanita
Answered By 0 points N/A #100099
Hello Madison,
Pysl is software you can use to filter and hide your SMS conversations. For installing Pysl first you have to add iClarified Source to your installer app. To do this you have to follow these instructions,
1. Launch the Installer in your SpringBoard.
2. Select the Source tab which is at the bottom.
3. Press the edit button which is at the top right corner.
4. Now press the add button which is at the top left corner.
5. Now set the source URL to http://www.iclarified.com/ and then press OK.
6. Now press the done button.
7. Press the install tab at the bottom of the screen.
8. Now select iClarified from the list of categories.
Now you have added iClarified as an installer source.
Follow the below instructions to install Pysl.
1. Launch the Installer.
2. Now select the install tab from the bottom list of tabs.
3. Now select the iClarified from the list of categories.
4. Now select Pysl from the list of packages.
5. Now install the selected package by clicking the install button.
6. After installing the Pysl package you have to reboot the phone.
7. After reboot you can find the newly installed Pysl in your SpringBoard.
8. Now press the Pysl and launch the application.
9. By pressing the Settings you can open the settings menu and from that you can add a password for your messages.
For more information please visit http://www.iclarified.com/832/how-to-keep-iphone-sms-conversations-secret.
Answered By 0 points N/A #100100
Setting Up iMessage in iOS for Message security just do that. Set up procedure is quick and essentially the alike on iPhone, iPad, and iPod touch. Tap on “Settings” and scroll to and tap on “Messages” Flick the ON/OFF control next to ‘iMessage’ so that it iMessage will challenge to automatically drag your cell phone number or Apple ID (or both for iPhone users).
