Hello!
I had just installed an NTI CD DVD Maker, but the problem is that the language is in Italian. I can’t understand Italian. Before I installed it, was stated that it is English. Please help me with it. Thanks!
How To Set The Language On My NTI CD DVD Maker?
Hi Laurie
Your problem actually is pretty simple, since there is some software programs that when installed checks out the following :
Your location.
Your time zone ( the time zone that you specify in windows settings ) .
Installed languages on the PC .
Keyboard languages .
All those previous points are taken in consideration when installing software programs, so in order to get rid of it check them all and make sure that the zone that you specified is in the country that you're living in, or if its Italy change it into an English speaking country, change all language options into English if the software didn't turn automatically into English probably you have to reinstall the software .
Regards
Bowen Courtemanche
